Water Storage And System.
Sleepy
Post by Sleepy »
The sickest I ever got was drinking from a mountain spring in Idaho!
Can you say amoebic dysentery. :(
I have drank from countless springs in the texas hill country and east texas with no effect.
James V
Post by James V »
I have hiked streams in Fl, Tx and Co. Don't really want to drink from them.
Boblee - What was the cost and time for the water bladder, filters and faucet?
Where is the intake and if you did it again, where would you put it?
How durable is the faucet?
Thanks.
Boblee
Post by Boblee »
James
Your costs for these things will be far lower than ours, usually a minimum 20% but the bladder was $124 AUS and the filter kit including faucet was $125 I used a premium food quality hose I think about $4 metre.
Cut a lot of costs by using a snazzy little tool to use stainless wire instead of hose clamps which will be handy for heaps of other things too.
The inlet is under the rear seat (see mod for rear arch), it is a two way valve, one way is for the shower and the other is a inlet/outlet depending on the configuration of the y valves for the pump.
This outlet is normally capped and when we need to use, just use normal garden hose fittings to attach 10m of food grade hose which can be used as a washdown or to drop into a water supply or attach to a mains faucet.
The pump is self priming and it will lift reasonably well but due to no vent on the bladder it is imperative that there are no air leaks or you get air in the bladder and then have to pump it out.
The faucet uses a ceramic disc if you go to http://cgi.ebay.com.au and water filters the one we used was from member supplier71 but think I changed to larger hoses, you should be able to find a comparable sytem (but cheaper) over there as the filter bodies are US made.
As for time have no idea, it was all part of several mods going at once and don't think there is anything I would change except the extra hole I drilled in the galley top for the extra faucet (not required).
Note we use all food grade hose to cut out taste/smell problems.
Thee are lots of swish sytems but many are much larger and dearer like$900 AUS but at the end of the day they only use similar cartridges except like the AMWAY one which uses a light or magnets to supposedly work extra miracles.
kziadie
Location: "Sundancer" 2006 26M Honda 50 MACM1338C606..... BAZS-3601239..... Central Chesapeake Bay
Post by kziadie »
My toy detector just went off... Boblee, can you tell us a little more about that tool?
Kelly
Boblee, is this what you're talking about?
Boblee
Post by Boblee »
Crikey nothing that flash Kevin it is actually made in the US and called clamptite. www.clamptitetools.com , very handy especially locally where stainless clamps/anything are hard if not impossible to find.
The hoses I had done months earlier had to be cut off the fittings I don't believe they would leak.
Has certainly found a permanent place in my toolbox.
AmyTom
Post by AmyTom »
I used pliers like that to attach safety wire to weapons systems in the Navy; not sure if I would trust it for replaceing hose clamps though.
AmyTom wrote:I used pliers like that to attach safety wire to weapons systems in the Navy; not sure if I would trust it for replaceing hose clamps though.
Yeah, that's what I use those for, too - I drill and safety wire my racing engines' critical bolts. But I have used that safety wire to make hose clamps and it works pretty nicely. You have to use about three of them, spaced about 1/8" apart.
