Foresail only?
Foresail only?
First, let me introduce myself: New to the board, but not new to the Macgregor: bought a new 26x in 1999 - one of the first 2000 models and sold it 3 weeks ago. Used it mainly for day sailing in the Naples Florida area, boat was kept in the water the first 2 years and thereafter I had it on a lift, the fight with barnicles inspite of bottom paint was hilarious! I live at a small canal (Gordons River) with brackish water, sometimes its like freshwater and sometimes saltwater.
To get out to the Gulf, I have to pass thru a low bridge (US 41), which presented a problem at high tide even with the mast lowered: I solved it by attaching a rubber stop to the right side of the mast support with an U-bolt, and that gave me about 4 inches lower at the mast support and enough to clear the bridge at high tide.
And that brings up the first question, since I am about ready to order a 26 M which has a different mast support: is there any way to lower the mast a bit more, like shorten the legs of the mast support?
Question # 2 is bout sailing with a 150% Genoa or Spinnaker only. So far (till I found that board 2weeks ago again after 8 years) I wasn't aware that the M does not have a backstay, and somehow I don't like it. Most of my sailing was just by myself, and most of the time for convenience and beeing lazy (semi-retired) I only used my genoa and that was just fine for me. Is it save for a 26m to do the same or is that putting too much load on the mast (without backstay)???
Hans
Hans
- marsanden
- Location: Southern Italy ...2001 Mac X ,"Diabolo",Merc 60 EFI
you can sail your boat ,only with a genoa, with or without backstay.
It doesnt a matter if there is a back stay on your sailing boat or not.
The backstay let you ceck only the position of the top of your mast and,
doin it , you can change the shape of your main sail.
Often ,sailing with main and spinnaker, any sailors leave - without force -the backstay.
- David Mellon
There is clearance to lower the gallows on my
The spreaders would cause the biggest headache. Many would say you could dance around the mast to tuck them under the safety cables. Others would slack the safety lines. In my opinion using clips to hold the spreaders in place would serve best. You could get another few inches clearance off the deck with them disconnected. Try a clip like this.
- Duane Dunn, Allegro
- ALX357
The X sails ok fine with the Genoa alone, and is balanced reasonably well that way. I find it easier to jibe about in light air than to head upwind for the tack, but it sails fine with the Genny alone.
My information concerning the M boat is that it will not balance well with the headsail alone. It DOES sail with the main alone, and is balanced much better than the X if sailed with the main alone. The X seems to need a fore-sail at all times to do well, but be prepared for a possibly difficult time sailing the M without the mainsail.
- baldbaby2000
There is room to lower the rear support. I can't say off hand exactly how much without looking at my boat.
There's been previous discussion on sailing on the headsail only. The argument against it is that the main sail provides a lot of support to the mast and without the mainsail things could get overstressed. I can say for sure that the main pulls significantly back on the mast by looking at it's effect on the forestay sag.
I've never heard of a 26M failure so maybe the rigging is strong enough but I would be careful anyway. I did watch a non-Macgregor break his mast while sailing only on the headsail.
I did add running backstays on my boat but not for that reason. I just wanted to be able to take some of the sag out of my forestay.
- parrothead
To see a running backstay setup, go to the Mac Mods page - it's currently 2nd from the top of the list of recent mod additions.
We have sailed our
under asym spinnaker alone, and it works fine. With the main furled, and the boom suspended from the topping lift, if you tension the mainsheet you get a similar stabilizing effect to a backstay. The advantage to running backstays over either a fixed backstay or the topping lift approach is that the balancing force is exerted directly at the point where the headstay meets the mast, rather than at the otherwise unstayed top of the mast.
I do plan to try adding runnning backstays this season, primarily for their pointing benefit when going to windward - am going to try terminating them at the stanchion bases near the winches, as our bimini would be in the way of running them to the aft corners.
We have sailed our
- NautiMoments
- Location: Vancouver, BC "NautiMoments" 2005-26M....Honda 50
Hans, it is no problem running an M with just the foresail or spinaker. I have sailed with a 150 Genoa only several times and I do not have running backstays. As parrothead said, with the boom straight the topping lift and main sheet to the traveler act as a backstay. You could try it first and see how you like it then add running backstay if you wish later. Best of luck with the new boat, the M sails great, and the blue hull is very very fast
- baldbaby2000
