Rob
You can get the manual for your Furler at
this page....jsut choose your model on the left hand side
The forestay runs up the extrusion, or plastic part, inside.
THey are not spring loaded, but are pulled out with the sheets, and rolled back in with the 3/16 inch (FF2) furler line in the drum. You wrap the drum in the opposite sense from the sail to be able to do this, so that as the sheet winds up, the furler winds in, and vice versa.
The Genny has to have a 'luff tape' attached by a sailmaker, which slides up the groove in the extrusion.
A fully deployed genny will have sheets outside the stays, as you furl it in you will eventually get to the same position as the jib. Sail shape in this configuration generally sucks.
You furl by pulling on the furler line, keeping some tension on the sheets to get a nice tight wrap.
On edit - I do recommend the optional ball bearing for the FF2 when used with the genny - its a fairly heavy sail for the running rigging size (especially that furler line) and getting the plastic bearing replaced with the ball bearing adds some good safety margin to the furling process.
