Headsail Longevity
- Carl Noble
- Location: Clinton Twp. MI (Former 2000 26X owner, regretting that I sold it:( Suzuki DF50
Headsail Longevity
I would like to know the average life span of a roller furling 150 Genoa with UV strips in place. Mine had 5 1/2 seasons without any protection and stored at a dock. (Season = 7 months.). I am questioning if the $200 investment will increase the life of the sail well past that time frame.
- Night Sailor
genoa protection
If your dacron sail lasted 5.5 years at the dock, then you can expect the dacron UV wrap to last the same. The difference being that you can replace the UV wrap for $200 instead of the whole sail for four times that.
If you don't dock in an extremely windy place, consider getting a genoa cover, raised by the jib halyard. My Mac factory optional Sunbrella cover is still in excellent shape after 9 years, matches the factory mainsail cover, and my 150 genoa is still in like new condition except for some dust (we get red mud storms occasionally) and s.s. pulpit staining on the foot. It will be years before I even have to wash it. I do have to wrap the jib halyard around it in windy weather to prevent undue flapping, which might cause wear on the sail from the plastic zippers.
waternwaves
- Carl Noble
I bought the new sail at bill@boats4sale for $340 which is only 40 percent more than the UV protection costs. The PO had purchased a sock for the boat but never used it. When I bought the boat I never used the sock as the sail was already deteriorated. I mostly singlehand and putting the sock up is a hassle. However if the sail will last 10 years then I guess I'll have to learn how to use the sock. Mine has three zippers. Is this the norm? Anyone have good advice for raising the sock?The difference being that you can replace the UV wrap for $200 instead of the whole sail for four times that.
- March
My gib sock has four zippers, sewn one after the other. I can handle the halyard single-handedly, puling it up and down and stepping on it. As the sock comes down, I feed it through the hatch. Same when it goes up.
I've been keeping my sails protected by covers, when I don't use them, even when we anchor overnight. Got the boat as used four years ago and the sails still seem to go strong--knock on fiberglass.
- pokerrick1
- Sailboat: Venture 23
Sail covers
My dealer IInmon) advised me NOT to get a Genoa Cover (has furler) because cost not justified in relation to replacement cost - - - so I didn't. He advised me to ALWAYS cover the main, even overnight, which I do.
Recently, after 9 months, the dealer replaced my Genoa with a new one because the original had a rip near the seam he couldn't explain nor justify - - - so he replaced it free of charge.
I was SHOCKED how much WHITER the replacement was than either the old Genoa OR the Main because of our So Cal sun
I now have a white Genoa and a sort of ivory Main
Rick
Rick
- Carl Noble
Having had three sailboats I have often wondered at what point a sail is considered blown out or in need of replacement. My new genoa has a much crisper feel and a little bit whiter than my mainsail (6 seasons) (which is always covered except when sailing) but I feel the mainsail is still in great condition. There was no doubt my old genoa was in need of replacement. I had to tape it several times last season and this season it just started to rip apart in the wind. This was definately due to UV deterioration. So my question is what do the rest of you consider a worn out sail?Amazing lifespan of sails guys. Both my sails blew out in less than two years.
Avoid the sock.mine has snaps with turn snaps at the ends and every third spot . these ruin itself and the sail. the snaps that turn cut through the cover and the sail,the plain snaps almost wore through the cover and marked the sail. I'ts a 150%genoa I'm waiting on a repair estimate for the sail. Don't get a cover with the snaps because if you get wind it will ruin itself and the it is supposed to protect
- delevi
Structural life of a sail is self evident. If it is falling apart, ripped, etc, it is time for repair or replacement. Performance life is a whole different issue and typically ends before the structural life. In my case, both sails started to look like bed sheets without holding much shape. The jib had a fish bowl shape and could not be trimmed properly without backwinding the main. It always needed to be undertrimmed, otherwise the performance of the main was severely compromised. The main usually blows out first on the leech. The leech will flap around. You can compensate for this with the leech line but eventually, you can't get rid of the flutter unless you get the same fish bowl effect on the leech of the main. Also, the heel and weather helm are increased significantly. This is a tell tale sign of blown out sails. I just went through the process of replacing both sails and the symptoms are now fully cured. The boat heels much less, with a huge reduction in weather helm and of course, goes faster. I can also trim the jib properly, even overtrim it (just to test) and the main is not backwinded at all. Hope this helps.So my question is what do the rest of you consider a worn out sail?
Leon
- beene
I have owned my Sandpiper 565 for 11 years. It has seen lots of action since I have owned it. First owned and sailed in the Florida Keys. Then off to Ontario Canada where it sailed the great lakes for years. The boat is a ’78 and still has the original sails. The only thing I could see them needing is a touch up where small sections of sewing have deteriorated.
- kmclemore
I also still use the original sails on my BW Harpoon, and they're just fine. I had them restored by SailRite, and they did a wonderful job... even replaced the sizing and they 'snap' just like new ones. They were also able to replace the logo on the sail, as the original 'ball-and-harpoon' symbol had become a little faded.
- Bobby T.-26X #4767
i use a sock for one purpose only...to protect the clean white jib while the mast is in the trailered position. once on the water, the jib is "sock free".
when in the trailered position, the jib runs along the mast and is extended out the bow utilizing a PVC "half-pipe" attachment mod.
by using a black sock, the jib is protected along the top from dust,dirt, and debris, even with the 20' x 30' grey/black tarp on top of the whole unit.
Bob T.
"DaBob"
Dinghy Motor: '06 2.5-Suzuki
Bob T.
"DaBob"
