I'm getting the X ready for it's first sail and noticed that the bolts on all the shrouds are only tightened to the point where they still allow the shroud tabs to move. Is this okay?
Question on upper and lower shroud bolts...tight or loose?
- Daves_knot_here
- Sloop John B
I'm not sure what this guy is talking about. If it's shroud tension, then they should 'twang' when the mast's up.
Edit: Oh, the up top tabs. Yeah, they should be able to move.
