Rudder bolts
fran trapp
Rudder bolts
Does anyone happen to know the diameter of the bolts holding the rudder on for a 96X. Mine are really rubbing where the steering is attached. I think that i need to get washers to lift the steering arm up. Any other suggestions?
LOUIS B HOLUB
- Sloop John B
- craiglaforce
I think I had a similar problem with my 97. The bolt was digging grooves into the gelcoat. I think it was mainly from previous owner stepping on the rudderhead. I put some washers under my bolt and that fixed it. I didn't want to risk bending it back. Nut sure the diameter, probably 3/8 or a tad bigger.
fran trapp
