Another important element during the anchoring process is the method of dropping the anchor. In fact, the word "drop" is misleading at the get-go. Holding the boat steady, gently lower the anchor to the seabed, and take note when the chain slacks to guage the actual depth. Next, the best case is to gradually pay-out the chain and rode while a Mate is slowly backing the boat away from the set point. This permits the anchor and shank to orient properly, with the chain and rode extending cleanly from anchor toward your bow. I can usually feel my Bulwagga take its own set well before I've reached my full scope.James wrote:How much scope do you need to set the anchor? From what I have been reading, it was 1/4 of needed length when setting and then let out the rest. Well?????
I arrived early enough for last October's Fleet Week to anchor very near Alcatraz. We then watched untold numbers of boaters, both sail and power, simply "throw" their anchors off the bow. The risk is in having the chain pile in a heap atop the anchor, or wrap oddly and prevent the anchor's setting. You want to be sure these Captains "toss or drop" with plenty of space to avoid your own anchor, and enough distance so you can see them dragging and warn them off.
Naturally I used my Bulwagga in this type of very crowded anchoring field, and later had to shorten-up my scope to 45', about 3:1 in depth of 12'. Any more than that and the Yahoos are dropping right on top of you. Facing due west thru the Golden Gate, we were uncomfortable by afternoon's end with winds over 15 knots, spray and swell and chop. Many, many boats dragged that day, had to pull up and move to reset. The Bulwagga didn't budge.
REMEMBER to LOWER that anchor untill you feel the bottom - it will treat you well in exchange!
