That Mercury Bigfoot 60 should be a great motor on your new boat. Collective experience on this forum would suggest your best choice is a 14" diameter prop at 11" pitch (USA sizing descriptions should be okay). Be careful on prop pitch! Since the larger 14" diameter prop is most common on much lighter weight boats, you frequently find only 13 to 21 pitch sizes, which are too much for the Mac. Be sure you ask for 11 pitch.
You are surely correct that boarding at the transom means danger for a swimmer. The 14" prop is no more risky or dangerous than the 12" prop (they are both deadly). Even in an emergency, the motor MUST be in neutral as a swimmer gets close to the transom.
My 26X has the optional swim ladder that mounts outside of (to left of) the port rudder. Even so, I never allow any approach to the transom until the motor is neutral or silent. I don't know if the 26M has an optional swim ladder like my X.
