waternwaves wrote:shame on you Kevin!!!
thinking that a an Iron monger would have the skills and tools to straighten extruded aluminum. heheheh
HAve to deal with the brittleness, low workability, inability to anneal, loss of structural strength, grain collapse, corrosion surface issues....... locallized stressees from the rebending rollers..... naw.... no thanks.......arrrrrrrrrgggggggghhhhhhhhhhhh..... most extrusions are considered non repairable.
not that I wouldnt try it.....
I just wouldnt trust it unless I could get 2 for free to test prior to implementing my repairs.
having to mess with the rigging strain, and the adiditional strength elements just hardly seems worth it.
Technically you are correct, practicality wise...people in our yacht club have rebent them straight all the time, including myself. It takes usually 2 people and the trailer makes a superb bending jig. Float the boat and use an empty trailer, not with the boat on! Using good size pieces of carpet, wrapped in stategic locations, and easing it gently back in to position, it can be done. It's more of an art than a science.
Before defeat, I advocate to at least try!
If you do bend it too far the other direction, throw it away! If you bend too fast it will snap. If you get some extremely minor cracking, strange marks that look like stretch marks, and are fearing that the annodization is compromised a bit, use clear spray laquer to seal.
All the characteristics listed by Water n Waves is totally true, but it certainly MAY not be a hopeless scenerio either! My statement is of course all theoretical in each case, looking at the pics, and it's description, if I lived a bit closer, I'd help ya myself!
The bolt rope slot, if too narrow can be opened up with an appropriate sized piece of metal, ran in the channel, and convinced with a hammer. Likewise, a wood 2X4 can be used to narrow the channel, that can be done several times in the same place with no worries of structural loss!
If you are faint of heart, or screw up, spend the $1000 bucks.
Or not, and live with it!
Either way, standing rigging tensions should be given the once over, and adjustments made!
.....and, if you decide to throw it away, I'll gladly take it off your hands!
