Winches how often
Winches how often
do you clean, regrease, etc., yours?
I just got my first boat and have heard a lot of different opinions. What say ye, Macgregor sailors?
Nick
Nick
- kmclemore
Well, winch manufacturers will tell you to do it annually, however, I think it depends a great deal on your conditions. If your boat's in a salt-air envrionment getting weekly usage, yes, do it annually by all means. But if you're only in fresh water and only occasionally use the winch, you can probably go 3-5 years or maybe more without any strip-down. Just be sure to use a top quality marine grade grease when you do the initial cleaning and lube.
Just IMHO, of course... your mileage may vary.
- argonaut
Careful with the grease there Hoss... there are parts you want to grease and parts that need a lightweight lube like oil, or you winches won't work right after you're done.
Two contributions that might help.
Sailnet Winch Maintenance Article
Also, APS sells the Lewmar Winch Maintenance Kit
Nice thing about the kit is not only does it have the correct lubricants but it also includes those pesky little parts that go "ping" and fly through the air and disappear into your lawn when you take the winch apart. (pawl springs)
It really doesn't matter if you keep your boat in salt or fresh water when it comes to annual winch maintenance. There are other factors that affect the winches including oxygen and heat.
Oxygen, it doesn't matter where you are, oxygen is an oxidizer. The winch grease is subject to oxidation rates no matter what kind you use. The longer it is exposed the more it oxidizes, and the more it oxidizes the thicker and stiff it becomes. While thick and sticky may seem like a good thing to protect the winch, oxidized grease is not a good protectant. The grease when old actually loses it's lubricating properties and the increase in friction of the less lubricating grease creates unnecessary friction between the parts inside the winch when it is used. The friction causes you to work harder, and the winch to have to deal with heat and wear not normally found when the grease is fresh.
Heat from the sun as well as friction are grease enemies as well. The hotter the environment the quicker the grease starts to oxidize and skim over. Then the same thing as above happens.
Don't be naughty and ignore your annual maintenance. It gives you a chance to clean the nasty old grease off, clear out the bugs that seem to find their way into the winch housing and live, and you really need to closely look at each pawl, gear, spring, and pin in a winch and make sure you don't see gear wear, metal bits in the grease, sagging springs, sloppy pawls or broken plastic rollers in the bearing cages.
Be nice to your winches, they are expensive buggers and can make your day miserable if they are bound up, slipping due to poor pawl care, or even the barrel fails. Cast aluminum has been known to have failures which often times can be seen as stress cracks before they break apart completely on a breezy afternoon. I saw a lewmar aluminum can do just that last summer on another boat. They came into the marina with a 5"X6"X4" triangle missing out of the drum with spider cracks at each corner.
If you use your boat every weekend, then you ned to service every 5-6 months. If you use it once a month or less, service it annually.
Off my soapbox now.
Off my soapbox now.
- richandlori
Lloyd Franks
Download the Lewmar manuals in the Owners Manuals thread
The Lewmar #6 is so easy to tear down, clean and lube, and reassemble, there's no excuse not to do it annually.
Cut a hole in the bottom of a shoe box that just fits over the drum to catch any parts that may fall. Then remove the circle/spiral clip and lift the drum off.
- delevi
Re: Winches how often
I had my boat for 4 years, mostly salt-water use and never did any maintenance to the winches. They work as well as they did from day 1.
Moe,
Speaking of how easy it is to remove... What do you thinkg the odds are of replaceing these with self-tailers while using the original bolt holes?
Moe,
- Loala
- Sailboat: MacGregor 26D
- Location: 96' 26X 40hp Merc. Bigfoot - SOLD! '88 26D now. Fast & Fun!
Hi.
They are starting to get hard to turn. Prolly haven't been oiled since 1996! LOL!!!!
