I believe the triple rear facing marker lamps should legally be on the end of the mast, or perhaps on the motor. Mac provided a cheesy plug in extension cord setup (wired with their standard white lamp cord) to do this on mine, though the trailer end connector is totally exposed and rusty, and it's such a PITA I've never used it, though I admit it might keep me from being rear ended. And for those who are wondering about my "incident", that one occured in the daytime
I wouldn't count on balancing the wheels to fix your fender shake problem. Unless yours are substantially different than the stock design, I think it's more a matter that the design has them cantilevered on long brackets, quite a long ways out from the trailer frame. The stock fenders do the same thing. I had quite a lot of shake on my new tandem fenders after the intial intallation, and found that the nuts holding the brackets to the frame were loosening up just like the lug nuts. Just like the lug nuts after tightening them a few times, they stopped getting loose,and the shake was reduced considerably though not eliminated. Try this before you blow the bucks on balancing and see if it helps.
I will be interested to know what is the wear pattern with your bias tires. I left two of the original ST215D14 on the original axle on mine (now on the rear). They are wearing quite badly on the outer edges, similar to gross underinflation, while the two new ST205R14 radials on the front axle are showing essentially no wear at all. Could be the tires or could be the location. BTW, smart move on the 205 versus 215; the 215 are virtually impossible to find when you're on the road ("Yes sir, we can order those and have them here in two or three days")
Did you find a buyer or some other use for the original trailer, or just scrap it? Wouldn't make much of a planter for your yard, I guess.
