New Boat/Travel Refrigerator Suggestions for 2026
OverEasy
Post by OverEasy »
Hi All!
It time for a new boat/travel refrigerator!
Our ‘old faithful’ thermonic ($20 garage sale) refrigerator has finally ‘kicked the bucket’ after five years of seasonal duty. It decided to do this just as we are preparing to launch for the 2026 season and hopefully an extended trip northward on the ICW from Beaufort SC.
We’d like to ask the forum for their experience, expertise, input and suggestions on what they might recommend for a replacement.
Our old thermonic was made by Coleman and fit nicely on the fwd bench of our Mac26X. Avialable Dimensions to fit into the same location are 24” wide x 16” deep x 17” tall (give or take an inch).
There have been various incidental discussions on the forum in the past about various different units avialable from various different manufacturers. Alpine cool seemed to be a common name that came up for some of the larger units that came with freezer sections but with our limited space I’m concerned that those would be larger than we can comfortably fit.
So if anyone out there has some suggestions for a good durable unit that can basically fit within our envelope we work be most appreciative!
Thanks in advance!
Best Regards
Over Easy 8) 8)
tuxonpup
Re: New Boat/Travel Refrigerator Suggestions for 2026
Post by tuxonpup »
I bought this Marsail 24QT 12V/24V last year to fit our X cooler space: https://www.amazon.com/Marsail-Refriger ... r=1-3&th=1
It fits in the back seat of our Santa Cruz and plugs into it's 12V outlet for the 6 hour drive up to Lake Powell. A 24qt works for us as I carry it in/out of the car to the hotel room, as well as on/off the boat. Might actually add the internal battery option for those times we park and want to leave it running with the car off.
1996 MacGregor 26X w/150% RF Genoa & Nissan 50hp 2-stroke
We have an Edgestar Fridge/Cooler. I see MANY options today that are much cheaper.
The most important feature is an actual compressor. Those thermoelectric things are a total joke.
Probably need to measure the space you intend to place it first.
Be Free
Post by Be Free »
I use the F40C4TMP 20Q model. I've been using it fairly often over the last 3 years and so far it's worked well. I'd say it's no better or no worse than most. I've occasionally thought that a little bigger version would be handy but it's been big enough most of the time.
If I needed to replace it, I'd be happy with anything that would run on AC or DC, had decent insulation, was reasonably priced, and was built around a compressor.
2001 26X Simple Interest
Honda BF40D
FittsFly
Post by FittsFly »
I too will be looking for a good option of fridge in the future. I'm assuming the thermo electric ones discussed maybe work on the same principal as the ammonia/propane models used in small campers for years? I used one for years in my small camper and loved it! The propane part of it was no more than a very small pilot light that would burn 24/7. Not that Im totally thrilled about bringing propane aboard has anyone seen any advances on those systems in the past years? I used mine back in the late 80's.
OverEasy
Post by OverEasy »
Hi All!
Thanks for the suggestions so far.
Please keep them coming! They are appreciated
Hi FittFly! :D :D
The thermoelectric is a little different than the camper unit you described. Our was one that could use 115VAC/12VDC/ propane.
We had that type in our camper as well… it was nice because it would automatically transition how it used the available power it had to choose from..
First choice was 115VAC, the when traveling on the road it would use 12VDC and then when disconnected from the tow vehicle it would use propane & run the minimal control circuitry from the trailer onboard batteries.
It was nice while it lasted but after a decade parts wore out and replacements weren’t available anymore.
At that time we opted to get a 115VAC dorm refrigerator with a top freezer compartment as a replacement from ‘Top Chef’ that was on sale at Costco. While it couldn’t run while in transit down the road most of the camp grounds we used had electric power so it was ‘goodenough’ for our purposes. It’s insulation was great and kept things cold and frozen even after a day of traveling through the summer deserts. (That was back in 1987. Now after 10s of thousands of miles bounced along the highways and byways followed by a stint in the garage as a beverage fridge followed by two separate multi year sojourns out of state at our daughters colleges only to be returned home to be transited down from NH to SC to resume garage duty but then when the original to the house house SC fridge gave up came back into daily use for several months while a new full sized house fridge was finally delivered which then promptly crapped out it’s fancy linear compressor for several more months while the manufacturer service folks fiddled about and now resides in the house kitchen as our overflow refrigerator/freezer. It has never skipped a beat even with all the moves, bounces, jolts, drops, storage & etc that it was never designed to endure yet still it does! :D :D )
The old thermoelectric we are looking to replace now utilizes a solid state electronic (no moving parts) device that utilizes a phenomena that when provided with 12 VDC power will heat one side of the device while simultaneously cooling the other side of the device. Pretty nifty!
We got our at a garage sale 5 years ago (and it was at least 10 years old at the time) for a $20 bill. It pretty much ran constant while the boat was in the slip and on our numerous car trips but it finally wore out. The downside was that the 12VDC power draw was a bit high and the fans to circulate the air inside & outside the unit could be a bit noisy.
Meanwhile time moved on and it appears that the newer 12VDC compressor type units have come a long long way and now appear to have lower power consumption and equal/better durability. Many now are even capable of having actual freezers that can make ice! Our problem is there seem to be so many to chose from with reviews all over the place such that it’s hard to determine which ones have stood up to a marine environment. That’s where we need some help from our community members.
There’s no point in going it alone when others have the experience and expertise to share.
Best Regards,
Over Easy 8) 8)
There seems to be a bunch of 12/24v compressor fridge/coolers on the market now. That wasn't always the case when we had essentially one manufacturer.
Buying one TODAY with so many choices can be daunting. I would rely on reviews. Verified Amazon reviews are always a good source for me.
Propane....especially an open flame pilot light on a boat is a no bueno. As heaver than air gas/fumes are an explosion hazard on any boat, propane can only be used under special safety conditions.
What we learn by owning boats with limited power/fuel is just how valuable 12v ions are worth and how much energy is in fossil fuels.
Thermoelectric (peltier element based) coolers are a joke and should be illegal to sell as coolers. They run constantly, consume so much power, and don't really cool. At best, they can keep stuff cool.
One of my favorite Youtubers explains how they work and why they don't work.
rsvpasap
Post by rsvpasap »
I have propane installed on my 26x and use numerous items that produce a flame including a diesel heater/stove (Wallas) and a propane fireplace (Dickinson p9000). Suggest having a propane solenoid and a hardwired propane / CO detector and to close the propane tanks manually when the boat is unattended. From my perspective, that would vitiate many of the benefits of having propane powered refrigeration.
If you're looking for occasional refrigeration for a few days, some of the portable 120v/12V refrigerators are much better than they were in years past. I sometimes use a BougeRV 30 q which holds the temperature well, is dependably built and is relatively quiet. I'm not saying its silent, but it's relatively quiet for a portable refrigerator. I have owned ARB and dometic portable chest refrigerators in the past and it's quieter than either of those.
I have experimented with refrigeration and freezer options extensively and think if you are going to be spending longer time periods upon the boat, a 120 volt freezer used in conjunction with a few freezer packs and a small well insulated portable cooler provides the most practical refrigeration setup for the least energy consumption. I exchange a freezer pack or two back and forth between a Whynter 2.1 cf freezer (which is very close to actually silent) and a RTIC 20 quart cooler each day. This requires only about 450 w (37 12v amps) per day on average and provides the most overall refrigeration and freezing options for the least electrical usage.
Starscream
Post by Starscream »
We're using this one:
https://www.amazon.ca/dp/B08D96FM73?ref ... tle_2&th=1
Price is right, real compressor, optional split between fridge and freezer or all fridge or all freezer. Our 100W solar panel can keep it going in good weather. It's been two years and it's fault free.
If I was to replace it, I'd look at the products on the BougeRV website. looks like they've got some great options, and good pricing. BougeRV has an option with some of their portable fridges to add a battery pack that would run the fridge without a power source, like if you wanted to take it for a picnic or something.
tuxonpup
Post by tuxonpup »
Starscream wrote: Tue Apr 07, 2026 7:18 am If I was to replace it, I'd look at the products on the BougeRV website. looks like they've got some great options, and good pricing. BougeRV has an option with some of their portable fridges to add a battery pack that would run the fridge without a power source, like if you wanted to take it for a picnic or something.
I just received the internal battery pack for our Marsail fridge yesterday, looking forward to testing it out. We also got one of these $9 rechargeable water bottle pumps, which works great and is a lot less noisy than the 12V pump mounted in our bilge:
https://www.amazon.com/Bottle-Portable- ... r=8-5&th=1
kurz
Post by kurz »
Now about the Vevor?
