I really want to thank you all for your suggestions, I take your advice seriously, and I’m very grateful that you noticed this issue!
I wrote to Mr. Todd on Sunday, and he replied with the following:
“Those have definitely been modified and are also definitely not safe. By reshaping them, the basic geometry of the rigging has been changed and the strength of the tubes has been compromised. The spreaders operate under a substantial compression load when sailing upwind, and the bend will greatly reduce their strength. My only guess is that the previous owner reshaped them so they wouldn’t have to tuck the spreaders under the lifelines for trailering. They should definitely be replaced with straight ones. FYI, you will likely need to readjust the length of the upper shrouds after you change them.”
I have to admit, I felt a bit down after reading that
I asked Mr. Todd if I could order original spreaders directly from him, but the problem is that shipping and customs to Greece are very expensive.
I also asked if he knows any suppliers in Europe where I could buy them.
Do you have any suggestions on how I could have new ones made locally? What material should I use, and can I find somewhere the exact measurements? From what Todd said, I’ll also need to readjust the upper shrouds once the new spreaders are installed.
Any advice or experience would be really appreciated
(Is there something else that I can do to make the mast more safe avoiding it not to fall forward but even not to fall backwards? I heard that it has happend that the mast felt backwards...It is only hold of the Forestay. For me it seems more dangerous that it could fall backwards then forward.)
Thank you all again for your help and for keeping an eye out for my safety!
Best regards
-Agi-
