Hi everybody
I wanted open the lighting to buy a new lamp, but I couldn't open it and was afraid to brake something.
Can anyone tell me how I can open it
Sorry for this stupid question.
And do you know if I can insert some better lamp? or what kind of lamp would you recommend to give a more white light and not so yellow?
Squeeze and pull down gently. There is an 18W incandescent bulb in there.
There are LED bulbs that will fit in the socket but they are quite expensive for what they deliver. You can probably find an LED fixture that will run on 12V for about the same price. When I replaced mine I picked up a 4-pack for a bit over $32 so I replaced both of the lights in the cabin and installed one of the leftovers in the head.
2001 26X Simple Interest
Honda BF40D
As mentioned above, pinch the sides and it will release the cover.
Lots of LED on amazon. It will make a HUGE difference in power consumption. Each incandescent bulb used as much power as ALL my LEDs turned on at once.
Try and support bwyachts. Its a macgregor-specific parts dealer based in Seattle. They have excellent support. Heres a link to the bulb you likely want on their site.
Thanks a lot for your information and for the link.
I would really like to buy so many things from them, but the shippment to Athens/ Greece and custom clearance make the prices so much higher:(
It would be such a releave for me if I could buy everything from them.
I have seen that they have really great products customized for the MacGregor.
