We have a 2004 26M with original 4-stroke Johnson (Bombardier) 50hp motor. The motor has been generally good to us but recently had some issues which were addressed but that made me wonder what our strategy will be when it's time to repower.. The boat is in the slip in So Cal and we go under sail as much as possible, however there are still times when we end up using the motor for extended durations (30mi-40mi runs) when we have to get back to home port relatively fast and the weather is not favorable to sailing. When we motor it is almost exclusively with full ballast and rudders down, so going hull speed. In fact there was only one instance since we bought the boat two years ago when we went on a plane for any amount of time - this was up in Salish Sea in BC where we had to make headway against a strong current thru narrows. So based on this use model, I was wondering if going to a modern 30hp motor would be an acceptable option.. I would of course prefer a 50hp but they have become so expensive lately and since we don't really plane the boat ever, I hope 30hp would do. Also, I do not want to go much smaller than 30hp to have some performance buffer when going against currents, big seas and the wind in a pinch.
Which brings be to the questions - any feedback would be greatly appreciated:
- anyone with 30hp on 26M or 26X, what are your impressions overall?
- with full ballast and 3 adults onboard, what throttle/RPM would 30hp run at when going 5-6kts in reasonable seas?
- will 30hp plane the boat at all?
- going from 2004 50hp Johnson to latest 30hp Suzuki, will the transom bolt pattern be different?
- would such repower be doable DYI by a reasonably handy non-mechanic or would I have to get it done professionally?
Thanks a lot in advance
