Got a bit of a pickle. The water ballest valve on my newly purchased 26s project does not seal. I checked it for debris but found nothing. Tightened as hard as I could by hand. Still leaks.
The amount of water it leaks almost keeps up with my weak garden hose.
I took a look at it today and it looks like the assembly is new, esp when compared to the rest of the 30 year old boat. Gasket, threaded rod, little rod, top gasket, washer, and threaded handle, safety ring... All look new. No rust, no corrosion, no warping of the rod (I put it on a flat table and rotated it).
However, you can see from the picture, and even moreso by eye, that one side does not tighten down on the gasket.
It doesn't matter which way you rotate it (I tried every whole twice) the gap is on the same side and looks to be the same width.
The picture is taken w the valve closed as tight as I can by hand (pretty tight).
My thought was to add a 1/4th inch neoprene foam pad (or two) between the gasket and the steel plate to provide more uniform pressure... Or maybe double the gasket?
What are your thoughts for a fix? This is not something I want to worry about while my wife and chikdren are sailing w me.
Thank you for all you're awesome help!
