The picture isn’t great but best I could do on my phone.
Basically there’s a small finger pier, about the length of my cockpit, on the port side when I pull in stern-to. There are 5 pilings, one aft
(and a little more starboard of centerline than the picture indicates), the two others are about midship, and the top of the pic shows the fairway at the bow. The centerline aft pile has my water hose on it, the port midship has electrical, which is great because it’s right where my shore power plug sits on the port topside.
The fairway piles have my current dock lines (red) lassoed around them thru the spliced loop, and the piles have two sets of hooks on them. The lower smaller hook is to keep the loop from slipping below high tide water mark. There are other bigger hooks at the top of the poles to hold the boat ends of the lines dry when I cast it off and leave the slip.
Each of the bow lines are tied to their respective cleat on the bow, not crossed. Each of the stern lines are looped thru the cleats on my boat, and crossed over the raised motor between the raised rudders, and lead to the cleats on the dock. The starboard dock cleat has my neighbors dock line spliced loop run through it, and I tie off a cleat hitch on top of his loop, which I cast off when I leave.
This system seems to work pretty well when I have a deckhand, but I’m not confident enough to try to single hand exit or return. I know I could practice with my wife on board for backup.
But, I have seen a few slips near me that run a single 3/8” line from the fairway pile back down to the dock cleat, which I imagine is a type of cheater like you can grab with the hook and pull the boat in hand over hand from the cockpit. I don’t have any spring lines rigged at the moment but I do have two extra dock lines in a bucket that could do so. And I also have nothing tied to the midship cleats which I believe are the biggest and strongest on the boat.
This pic shows in blue that cheater line idea and yellow possibly where I should have spring lines??
Any tips on how to improve my setup or on how to make it easier single handing a slip like this?
The scale of the pic is off but I’ll include a picture from port and starboard angles so you have a better idea. I can pretty easily jump from the cockpit gunwale to the finger pier and tap all the piles from the deck with an extended boat hook.
