Q1: My forestay pin has caused the hole on the steel strip (MacGregor calls it the chainplate in the front) on the stem to have become widened and elongated such that now there is quite a bit of play when the pin is inserted. I started using the second hole towards the midship of the first one, and that has been fine, but was hoping to either (a) get the holes weld-filled and then drill new holes, (b) get a doubler welded on this steel strip, or (c - less painful option) get another hole drilled below these holes. I could always slacken the turnbuckle inside the CDI-FF2 to increase the length upto the new hole in steel strip. Another alternative is to (d) change the metal strip if it was replaceable. Any idea if this strip is replaceable?
Q2: My CDI-FF2 cup:- Should the slotted opening for the Furling-line (blue/white thin line from BWY) be facing towards right aft, or to the Port? My last season I had put it facing aft, but furling line, that should lead outwards towards the fairlead in the bow railing, would be leading more fore & aft and would get chafed, so I used a leading block somewhere in the middle of the foredeck to avoid this. Want to confirm from others if this slot (in the steel cup) should be facing to Port.
Q3: My CDI-FF2's black "Roller" sits on the Thrust Bearing and the steel washer, but, when I pull the jib-sail to furl it, the black roller tends to lift up and is not sitting tight on the bearing; it comes up almost 3 inches! Do I have a pin adrift that should be between the metal cup and the roller (the roller does have a hole where a pin 'could' go?
Q4: My MacGregor 26M Manual states that when installing the shrouds, the clevis pin (and ring-ding) should go into the 3rd hole of the chain-plate, but the photo shows the 4th hole. The shrouds would be a bit loose - what is advisable?
Q5: Putting the Forestay pin is a terrible exercise if the shrouds are to be decently taut, I'm NOT aim for rod-tight! And slackening the turnbuckle is another exercise if you have the CDI-Furler in use. Therefore, I am thinking of having a safety line always rigged from the mast-head to the bow-pulpit (railing, around the Running Lights?) and take weight on this line while attempting to put the pin into the forestay hole. Comments? I plan to put a block on the mast-head using screws, facing forward, as to each side of my mast I already have a block for (a) Mainsail Halyard, and (b) Boom Topping Lift. Now, I could just pull on the Mainsail halyard and get the forestay pin to slip into the hole, but with so much fear of losing the pin and thus the mast, I'm contemplating this second 'safety' forestay with not much wight on it. It should not come in the way of flying my jib, and I do not plan to have a spinnaker immediately? Additionally wondering how high should I fix the block on the mast - I'm thinking of going all the way to the tippy-top of the mast!
Q6: Planning to have a couple of flags on the spreader arms, by putting a block each. Again, these should not interfere with the main-sail.
Q7: While hauling out the boat and bringig it home, the centerboard was left approx 6 inches outside. Not a huge deal except that the boat would not come all the way till the rubber bumper for the stem since the centerboard touched against the trailer's athwartship steel-wire on which it should normally rest! All was well, though I suspect that a steel shackle-pin has rolled inside the slotted housing of the centerboard and is stuck somewhere there (when I put the boat back and disconnected the truck, upon climbing up on the boat I discovered my steel shackle to the upper shrouds had worked loose and come off (pin is supposedly inside the centerboard housing)! Another exercise to be worked this fall!!
#8: However, happy with my tarp cover support this year....
Thanks for any guidance, and for the time taken to read the post!
