Galley top, vee berth extension, and miscelaneous thoughts
Slartibartfast
Post by Slartibartfast »
Hi all! Just thought I'd post some pictures of this weeks projects and see if anyone has any ideas or just for inspiration. I've had the boat for about a month and am hoping to launch in another month or so.
Here you can see the salon with extended V berth and all seats now at the same height in the salon. I think this will be better both for sleeping and lounging around the table. The flooring is teak patio tiles from amazon. They ride a bit off the floor, so moisture should soak through and evaporate. They do clip together better than in the picture, it just wasn't a priority for me at the moment.
Below, the hinged galley top is visible. The counter that touches the hull was scribed to match the contour of the hull, then I put a 1x3 upright to create a cubby (barely visible), then hinged the rest of the galley top for easier access to plumbing and other systems
Here's a detail of the V berth extension and settee. The grate in front is a piece of decorative sheet metal from Lowes. Breathable, light, and pretty.
Detail inside the settee and new storage box. I drilled straight up through the old storage lid for some supports, and just velcroed some of the others to the hull. Since they should only get compression force from people sitting on the settee, I think this should be fine.
A not very intuitive photo of how I fastened the new galley top onto the old frame. When I cut out the old top with a jigsaw, I ended up with a lip all around the outside of the galley (convex on top, concave inside). I drilled straight through this lip, passed a screw through, and put a wing nut on from the inside. The wing nuts were really easy to work with upside down and, once they are threaded on the screw and inside the concave lip of the galley, they can't turn on their own,making them very easy to tighten from outside. I don't know if that makes any sense.
Do people like the original galley storage that came in the 26X? It seems like it's pretty heavy, bulky, and impractical, so I'm looking for insight into whether it's a good idea to delete and replace it. Might be my next project.
OverEasy
Re: Galley top, vee berth extension, and miscelaneous thoughts
Post by OverEasy »
Hi Slartibartfast!
Interesting handle! Gotta be a story behind that somewhere….
Like what you did!
Nice!
Looks like it works for your needs which is the most important aspect.
The galley is one of the more popular modifications folks have accomplished.
There are several postings within the forums of the various projects accomplished.
Thee are also several listed in the “Mods” section as well.
A variety of approaches have been taken by a variety of people to suit a variety of needs.
There are a lot of options only limited by what you want to do.
Best Regards,
Over Easy 😎😎🐩🐈
Be Free
Post by Be Free »
HItchhiker's Guide to the Galaxy. He won an award for the fjords.
Bill
2001 26X Simple Interest
Honda BF40D
Slartibartfast
The mods section is so helpful. @overeasy if I delete my galley, I'll probably do something similar to your idea with plastic shelves.
