The winches on my 26m dont grip the line well. It appears that the plastic drums are smooth from years in the sun. I really only use one to get the last few inches of mainsail up.
Can the be repaired?
Maybe roughen up the plastic with sand paper?
26m winches slipping
Macsailing
- Jimmyt
Re: 26m winches slipping
Are you taking 3 wraps and keeping the tail tensioned? Since the winches are not self-tailing, they have to be tailed manually.
Is there something amok with your main sail/halyard? I raise mine by hand. I have a bolt rope in the slot, so mine should be about worse case.
Jimmyt
P-Cub-Boo
P-Cub-Boo
- NiceAft
Here is a visual that may help. A lot of information which you probably don’t need, but pay attention to line placement.
Ray ~~_/)~~
- pitchpolehobie
Clockwise
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Tohatsu 25HP
Macsailing
JimmyT, you nailed it. I didnt know the difference between tailing and self tailing. In fact i have only used tailing so I thought these should work the same, my Mac newbie erworm.
They work fine when i tail them manually.
Thanks
Thanks
2010 26m, suzuki bf70a.
San Diego Bay
San Diego Bay
