Bimini middle bow missing
Bennkat81
Post by Bennkat81 »
Opened up bimini for the first time. The middle bow is missing. I don't know if this is the original bimini or not. Anyone know how to identify it. Looks like 3/4" stainless frame 3 bow. Fits the the jib slide holders. Aporox. 70" wide frame at the base.Has a sleeve the mid bow should fit through on the cover. 2008 26M
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
pitchpolehobie
Re: Bimini middle bow missing
Post by pitchpolehobie »
ID try and take a picture. Some were after market. I have ordered replacement parts and tubes on eBay with the correct dimensions sent to the seller.
2002 MacGregor 26X: Remedium
Tohatsu 25HP
leefrankpierce
Post by leefrankpierce »
Where are you?
I am in Dallas Fort-Worth. Removed my presumably factory bimini and replaced it with an aftermarket, still have the frame.
Edit: I was looking at your profile and saw an X, but your post says an M.
Mine is from an X, replaced with one of these:
https://oceansouth.us/product/3-bow-bim ... ft-length/
Seems an upgrade, so would recommend.
Had to cut main support poles down to get under the boom, but otherwise it came off looking like it was designed for the spot.
26X in Dallas Fort-Worth area Texas
Slip at Eagle Mountain Lake
:macx:
Bennkat81
Post by Bennkat81 »
Gotta fix the profile. Had an X but had too many issues. Sold it and did not plan on another boat.Then I came across this M so back on the water again. In Mobile, Al. Previous owner doesn't know if the Bimini is original or not. When I found the middle bow missing I was hoping to find an inexpensive replacement rather than buy a whole new Bimini since the frame is stainless and fabric is in good shape.
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
Bennkat81
Post by Bennkat81 »
Pitcnpolehobie
The replacement tubes, did the seller make one or happen to be selling the size you needed?
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
pitchpolehobie
Bennkat81 wrote: Wed Nov 02, 2022 1:37 pm Pitcnpolehobie
I sorry I meant that some of the biminis were after market so some of the 26M owners might be able to help more seeing a picture.
Tohatsu 25HP
Bennkat81
Post by Bennkat81 »
Ok now I understand. When I get back to Knot T1 I try getting some shots. Thanks.
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
Post by Jimmyt »
Bennkat81 wrote: Mon Oct 31, 2022 10:06 am Opened up bimini for the first time. The middle bow is missing. I don't know if this is the original bimini or not. Anyone know how to identify it. Looks like 3/4" stainless frame 3 bow. Fits the the jib slide holders. Aporox. 70" wide frame at the base.Has a sleeve the mid bow should fit through on the cover. 2008 26M
My 2013 M has a small Bimini with only two bows (no middle bow). It's possible that you have a two bow frame (original), with a 3-bow cover (aftermarket replacement).?... maybe. Or do you see evidence that there was another bow at some point?
Bennkat81
Post by Bennkat81 »
Jimmyt,
The frame has the fiitings for the middle bow to fit in. The cover has the sleeve. It is good to know what the original should look like. Guess I have an after market cover and frame. It is larger than I expected. Now I need figure out who made it. Easy Peezy !
It mybe taller also. With the main up the boom drags over the top. I tried just to see if it would clear it. Shold the bimini be low enough for the boom to clear with main up?
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
Post by Jimmyt »
I sail with mine up to avoid the sun. I’ve gotten to the point of making the payments on my dermatologist’s new boat, so shade has become important. It blocks the view of the main most of the time, so you have to move around to get trimmed.
If you’re going to do much sailing, I’d want it low enough to clear the boom. If you mostly motor, maybe the extra head room is worth it; and you just do without on the rare sailing outing.
Personal choice, really. Or, as we like to say, your boat; your rules.
I’m thinking that some folks have raised their boom and cropped their main to fit a bigger bimini.
Be Free
Post by Be Free »
I've had success adjusting the base of the bimini aft to give a small forward tilt to the cover. On my boat it gives a little more clearance to the boom that way.
2001 26X Simple Interest
Honda BF40D
Bennkat81
Post by Bennkat81 »
Jimmt,
Iplan on sailing mostly. So probably try to how low I can get to miss the boom and how much head room that would leave. I usually saol with long sleeves and a uv protection hat so sailing with bimini down is fine. Hope the weather warms up.next week! :macm:
Ben
2008 26M Truluv
Honda BBDJ40
Sailing Mobile Bay
