Mast wire deck connector
green
Post by green »
Looking over my new 2005 :macm: I see that the mast wire connector is broken. Does this require a whole new wire and plug or just a new plug? A bit of googling suggests that these are universal plugs.
(You’re dealing with a real newbie here, so assume a lot of general boat/electrical knowledge if you reply)
Re: Mast wire deck connector
If you wire is long enough, just a plug. My foot has ripped the wire out a few times over seventeen years.
DaveC426913
Post by DaveC426913 »
It'll be fine. Just means your Spotify playlist will only be in mono.
green
Post by green »
I assumed this was a wire for the light on the mast.
DaveC426913
green wrote: Thu Jul 07, 2022 2:54 pm
And today you learned there are people who know less about boat electrical systems than you. :D
(I am of zero - possibly negative - usefulness here. :P )
Be Free
Post by Be Free »
You can get a replacement at Blue Water Yachts for $17.00 https://shop.bwyachts.com/product-p/8304-1v4.htm
2001 26X Simple Interest
Honda BF40D
DaveC426913 wrote: Thu Jul 07, 2022 2:45 pm It'll be fine. Just means your Spotify playlist will only be in mono.
:D :D :D
Always a joker in the crowd. 8)
This is the replacement plug.
That plug goes to the steaming light for use while under power at night.
BTW...when later you decide to install an anchor light on top of the mast, you can use the same plug and 2 wires with a diode to control both fixtures.
That's how I did it.
See:
https://macgregorsailors.com/mods/index ... tem&id=453
green
Post by green »
That's really helpful, Russ!
leefrankpierce
Post by leefrankpierce »
26X in Dallas Fort-Worth area Texas
Slip at Eagle Mountain Lake
:macx:
