with lots of patience
here,s the link
viewtopic.php?p=272670#p272670
If you bought the correct main sail, the only way the boom can be raised is if you have room at the top to raise the sail further up the mast. This will require raising your boom attachment point (and boom). Since you have a loose footed main, your idea of simply raising the tack may be ok - if you have room at the top and don't mind seeing the boom at an angle. You'll have to see how this idea impacts your single line reefing setup also.Sheppie62 wrote: ↑Sun Feb 13, 2022 9:01 am My boom is quite a bit lower with the new loose foot sail (changed from bolt rope to slugs type sail) I also do not have a topping lift or a boom kicker, is this necessary for this new kind of sail? I looked into adjusting backstay, but it’s adjusted all the way out. Only thing I can think of is to add a few links on the tack part of the sail and hope it will go up that much more.
This is a great setup.
I once had a downhaul for the main sail rigged to the cockpit, got rid of it, easier just to grab the sail leech and yank her down if need be.Sheppie62 wrote: ↑Thu Feb 24, 2022 10:35 am Starsream wrote: My next "easier" project is to fix the topping lift. My topping lift is a line led from the top of the mast to the end of the boom. Right now, I have two snap-shackles on the topping lift; one for normal sailing to keep the lift loose, but in place while the sail supports the boom, and another, higher up, to support the boom above the dodger when dousing the sail. The higher snap-shackle can be a pain to attach and release, and I'd prefer a pulley system. That might mean mounting a block on top of the mast and running the topping lift down the mast and back to the cockpit through a jammer, or maybe I can rig something simpler and easier right on the tail end of the boom.
first how do you use the qoute thing? I forgot about the topping lift line, I only have the backstay clip, and what is the benefit of a topping lift line over the backstay clip or boom kicker/boom vang? This sailing stuff is really confusing! But I am learning thanks to you guys helping!
