I usually sail alone, so that's probably a big reason why it seems to take so long. I'm sure it would go a bit faster with a 'crew' that had their own individual assignments and were practiced at doing it.
I'm interested in any tips you have found that help the process go faster.
I used to fully remove the stays, coil them up, and tuck them away inside all nice and pretty. These days I just leave them attached to the mast and and chain plates and bungee them to the mast when I tow somewhere. It seems to go faster this way, since attaching stays to chain plates tends to take a good amount of time for me, but then again dealing with all the bungees and potential tangles takes a while as well, so maybe I'm not really saving the time I think I am.
I've also started leaving the mast raiser attached after lowering the mast, and towing with it connected as shown in this picture.
Once the mast is raised, I do usually disconnect it and hang it on the port side forward life lines on some clasps tied to the tops of the stanchions. Both of these steps do save me some time compared to taking the mast raiser down below and storing it under the port benches like I used to.
Any tips you guys use for setting up and packing up more quickly so that you have more time on the water and less time monkeying around in the parking lot?
