Hi Jcromett
First, CONGRATULATIONS on your new Mac!
Wow! Someone wanted to seal up something!!!
I can’t immediately recall any Mac ever having that kind of a feature….
If one were to guess one might assume that the modifier wanted to make an under lip flange for a rested lid but that would only explain the outer perimeter of screws …. Not the inner perimeter set of screws…. Nor the extra two in the more central area….???
The corrosion you mentioned might possibly be old adhesive like 5200.
If so then maybe someone wanted to make that compartment water tight??? Why???
A built in fresh water tank maybe?
But there would have to be a fill port and a drain line somewhere….
An extra water ballast compartment to increase sailing stability?
But that area is higher than the normal ballast fill vent would be….
Looks like you are well on your way to a mystery!
If you haven’t already done so, soaking the screws with a light penetrating like WD40 might help with corrosion.
If it is old adhesive a little bit of warming with a heat gun should soften it some.
Maybe a combo of both penetrating oil after heating?
Good luck!
