26X shroud and backstay tension
I measured my uppers and they were both 33.
My lowers were 8 and tightened to 14.
My backstay was less than zero and tightening with my weight of 170lbs brought it to 0
https://www.marinechandlery.com/media/c ... auge_1.jpg
That's the gauge I used
We used this guage and my shrouds are 1/8 so the above measurements would correlate to
Uppers ~33= 320lbs
Lowers~14=120lbs ish
Backstay ~0=0ish lbs I suppose when at the dock? Diff when downwind?
Reviewed this: http://www.bwyachts.com/rig_tuning_tips.htm
Am I in the right neighborhood?
- pitchpolehobie
Last edited by pitchpolehobie on Sun Jun 27, 2021 4:28 am, edited 2 times in total.
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Tohatsu 25HP
- dlandersson
Re: 26X shroud and backstay tension
Ok, my backstay is generally pretty slack?
pitchpolehobie wrote: ↑Sat Jun 26, 2021 5:54 pm 26X shroud and backstay tension
33= 320lbs
14=120lbs ish
0=0ish I suppose when at the dock.
- Be Free
The backstay does not do anything unless you are running (wind behind you). It is not unusual for it to be slack at other times.
Bill
2001 26X Simple Interest
Honda BF40D
Honda BF40D
wakataka
Sounds like you could still tighten it up a bit. Here's a good thread on rigging
http://www.macgregorsailors.com/forum/v ... 26&start=0
- pitchpolehobie
seems to be a pretty useful thread. thanks! im gonna keep working on it and post updates. Ill say with my above numbers the boat felt a little "smoother" going on tacks in 20mph wind today. Seems my inner shrouds could still be tightened up a touch.wakataka wrote: ↑Sun Jun 27, 2021 6:21 pm Sounds like you could still tighten it up a bit. Here's a good thread on rigging
Tohatsu 25HP
Tohatsu 25HP
- Be Free
Sounds like you are starting to get the tension dialed-in for your boat. At 20mph I've found that the
is happier with at least a single reef. I go faster and things stop falling off other things.
Bill
Honda BF40D
Honda BF40D
