This pic seems to show a fiddle block laying in the cockpit just outside the companionway hatch, and some sort of attachment point, though no traveler.
Even a blind hog finds an acorn once in awhile...Tomfoolery wrote: ↑Fri Jun 18, 2021 6:54 pm
The first boom pic in your next post shows a bail on the boom. So it looks like it is/was rigged the way Jimmyt suggested, with a fixed attachment to the cockpit sole.
The small line hanging off the backstay could be your topping lift. It attaches to the back end of the boom to keep it out of the way when you don't have your main sail hoisted.GonePostal wrote: ↑Fri Jun 18, 2021 6:24 pm And on a side note... These are pics of how my backstay is connected to my stern... as per my other thread on standing rigging my boat. Im honestly not sure if its relevant.
The backstay adjustment is the same sort of rig that is used for a main sheet. Don't suppose you have another one of those on the boat somewhere?
Those clip looking things are how you attach the jib to the forestay.GonePostal wrote: ↑Fri Jun 18, 2021 5:45 pm And some of the boom. What are the two clip looking thingys???? On the sail that is...
No, it’s not. You have a back stay. That little tail is to support the boom when not sailing, to keep it above your head and so you can unhook the main sheet that’s (probably) in the way in the cockpit. And the chain plate on the stern rail wouldn’t be there if there wasn’t a back stay, either.GonePostal wrote: ↑Sat Jun 19, 2021 5:27 amIm not sure now if I even have a backstay... if Im reading things right. Is that okay???
Are you completely out of blocks and lines? I don't know that your backstay adjuster needs to be that beefy. If you have a lighter set of blocks and lines aboard, that could be your backstay adjustment, and the heavier set may be your main sheet rig. But, as Tom says, you have a backstay, and need to have it properly rigged.GonePostal wrote: ↑Sat Jun 19, 2021 8:28 am Hey Tomfoolery...
I hear what youre saying. I guess I was just asking if I had my backstay hooked up properly...????
This block & tackle looking thing that sorta looks like a boom vang... well thats what I supposed was to tension my backstay.
I was HOPING that it was part of my backstay as Id hate to hafta find a different place for it :/
Im hoping that when I go out tomorrow and set it all up that itll all fall into place.
