Inquisitor wrote: ↑Sat Jan 16, 2021 3:00 am
ris wrote: ↑Fri Jan 15, 2021 2:53 pm
Picture of our 30 gallon water bag completely full. We have this bag tied down in the most forward compartment under the V-berth. The small end is the most forward part of the bag and the port is the vent line when filling the bag. The water is added and removed from the port in the large end of the bag which is also the lowest part of the bag
Richrd
NiceAft wrote: ↑Fri Jan 15, 2021 5:07 pm
ris,
We too use a 30 gallon Plastimo bag under the V birth.
Fantastic setup. I'm Inquisitive (Couldn't help it
) This 30 gallon bag (250 lbs) up in the nose... One in an X and one in an M. Do any of you sleep in the V-berth and how does the boat sit in the water then and when sailing? And actually a little nose down (heads up) while sleeping might be a good thing.
Don't really want to open this can again, but I'm assuming you mean removing the forward Styrofoam?
Along with ris and I having two different Mac's, we also use them completely differently.
(1) He modified his
to be only used as a power boat.
(2) He uses the V berth for sleep; the admiral and I use the aft berth.
(3) He takes extended, extremely extended, and extremely extremely extended trips; we may do an overnight occasionally (we have been planning a week trip for two years, but family and then Covid-19 have got in the way).
As to the removal of the Styrofoam, I am not a believer in removing safety factors. Truth be told, I don't know if the foam was removed, I never checked.
When I purchased my 2005
in October 2004, I ordered it with many extras, which were installed by the dealer. One of which was the water bag, electric pump to power the sink faucet and the shower in the stern. Being a novice to a large (to me) sailboat (over 14' [4.26m]), I did not think about how it was done; blind trust in the dealer. I had sailed a Phantom for 25 years. Quite a steep learning curve.
The one thing I do every year is to fill the bag with a heavy concentration of bleach to H2O, let it sit a bit, turn on the pump, the faucet and shower to saturate the complete system. This will remove any mold that grew from the year before. I verify by checking the clear tubing. We don't use the Plastimo for drinking water. We have two large portable water bags attached to the hand pump faucet on the sink. We use that for cooking. We have a quantity of bottled water for drinking.
