I'm right handed. I remember working with a guy who was left handed but I hadn't noticed, or had forgotten. I mentioned how I'd come across an adjustable wrench that was threaded backwards, 'some kind of cheap import I guess', brought his response of how right-handed the world is, and how unfair it was to those lefties.
Anyway.
I don't have the Honda ZW7-V51 flush mount control yet but I did get some time and duct tape to play with ideas.
Why wouldn't it be cool to have a totally unobstructed walk on the starboard side. I know walking coolers through there sucks.
[/img]Putting the control on the port side is a most recent development, building the flushmount in - (slicing through whatever I have to) to make the cockpit even an inch more roomy just makes sense.
Also in the overhead pic above, you can see how the control is rotated around and tilts into the pedestal tube for close to a straight shot for the control cables.
[/img]The helm's view shows how the throttle lever in its neutral position is tucked close to the wheel and shouldn't interfere with anything. You can also see from this view how the lower left corner of the stock helm box is in the way.
In neutral while sailing tucked between the wheel and the pedestal, full throttle points almost straight up the line of the tube (I'm assuming my soon to arrive flushmount will operate similar to the old control ZW5-621 - just under 180 degrees of travel from wide forward to reverse), pushing the control into reverse shifting and some throttle is easily reachable. You probably have to stand slightly to get her in full throttle reverse, but that's got to be a rear maneuver.
[/img]
