Robert wrote:The Dodge minivan is notorious for transmission problems, check to see if yours falls into the group known for transmission problems. One person posted here that he had been using his warrantee to replace the Dodge minivan transmission every year as an annual maintenance because of using it for towing.
I agree that the Dodge has a
reputaton for bad transmissions, but it is not the tranny's fault. I'm an owner of a 1997 Dodge Caravan Sport, and I've got lots of miles on mine, towing my smaller boat on many, many trips, fully loaded with wife, kids and all their gear. Never had even the whimper of a trans problem.
Nearly all the trans problems with the Chrysler vans can be traced to using the incorrect transmission fluid. These cars take *ONLY* "Mopar MS-7176" fluid, also known as "ATF+3"... Owners should NEVER use Dextron III, which is what most shops will put in unless you buy the fluid and literally hand it to them. If you use anything other than the proper fluid you're pretty much guaranteed to have a tranny failure, since the transmission computer expects a certain level of 'slip' for that trans. If the fluid is too 'slippery' or too 'sticky' the trans will not properly regulate the clutches and they will burn out in short order. And once you use the wrong stuff, even for a short time, it's the death knell for that gearbox - it's only a matter of time. Symptoms include juddering and chatter from the trans - once that happens it's time to sell it or fix it.
It doesn't help that some of the Chrysler cars came with the dipstick marked "Use Dextron III"! And I've even seen Chrysler dealers make this lubrication mistake, so you can't count on your dealer doing it right, either. I always change my own, but if an owner doesn't want to do it themself then they may want to actually buy some legitimate ATF+3 in their local parts store and hand it to the guy/gal who services the car. Change it once a year, and that tranny will last a long, long time.
