Galley Mod 26X
Hooky
Galley Mod 26X
Post by Hooky »
I removed the original galley storage and replaced with three sliding draws, a cutlery draw and a large cupboard door, The mod created much more storage space with easier access, hope you like the mod
Re: Galley Mod 26X
That is beautiful work.
What is the heat source for the stove, gas or alcohol?
Re: Galley Mod 26X
Wow, that is beautiful work.
I'm curious where does that drain hose go to? A thru hull?
Re: Galley Mod 26X
Post by Jimmyt »
Very nice! A lot of useful storage created with that. That will make the galley area so much nicer to use!
adudinsk
Re: Galley Mod 26X
Post by adudinsk »
Nice Work!
Hooky
Re: Galley Mod 26X
Post by Hooky »
NiceAft wrote: Fri Apr 17, 2020 4:45 am That is beautiful work.
Alcohol stove
Hooky
Re: Galley Mod 26X
Post by Hooky »
Russ wrote: Fri Apr 17, 2020 6:05 am Wow, that is beautiful work.
Hi Russ, it’s a thru hull, I extended the cupboard floors a sides and glassed them direct to the hull
Greek_sails
Re: Galley Mod 26X
Post by Greek_sails »
This is very nicely done, did you add it on the original galley? I purchased one recently and it just has plastic drawers so I am thinking of doing something similar to what you did(if it is on the original), but due to the lockdown I cannot go to the boat do you happen to have the measurements of the inside?
Inquisitor
Re: Galley Mod 26X
Post by Inquisitor »
I've never been inside an X. Is that mods to the original galley or a completely new one. Either way, it looks so much nicer than the stock M galley.
I gather the X doesn't slide???
ris
Re: Galley Mod 26X
Post by ris »
The X galley is fixed in place.
Richard
kurz
Re: Galley Mod 26X
Post by kurz »
Cool. I like the white color!
OverEasy
Re: Galley Mod 26X
Post by OverEasy »
Wow! Nice work! Simple ,clean, even elegant!👍😎
Democritus
Re: Galley Mod 26X
Post by Democritus »
Beautiful! So much more usable space!
What are the grates under the table for?
Vince
"Spiraling Shape" 2002 26X
Tohatsu MFS50A
C Buchs
Re: Galley Mod 26X
Post by C Buchs »
To open your drawers, I see you have a latch that you reach through the hole to operate. Can you post more information about what latch you used?
Jeff
OverEasy
Re: Galley Mod 26X
Post by OverEasy »
Hi!
Beautiful galley mod! Nice job!
Now how do I keep this hidden from my wife ........
Opps, too late!
Guess my dual battery/wiring upgrade/new chart plotter/triple bilge pump install project just got a galley upgrade feature.
Fun times full speed ahead........
