Scupper drainage
Infoformacgregor
Scupper drainage
I am a new owner of a 26M. The scupper just under the motor will not drain. I have carefully fished wire,etc through the drain but it won’t pass. The boat is in a slip. Is there a plug on the other end, or has this happened to others? Thanks, Gene
- 1st Sail
Re: Scupper drainage
Assuming the thru hull was drilled like mine it should exit the transom wall approx 1-2in above the boot strip/(water line normally loaded). The transom drain is t connected with the sink drain. If your drain hose is translucent you should be able to locate the blockage with a flash light.
I find blasting the outlet on the transom with a hose to force stuff back up and then blasting the drain in the motor well will unclog stuffs.
The drain goes to a T where it meets the sink drain. From there it goes out the transom.
It's always getting clogged. Some folks have run a string through there to pull clogs out.
- NiceAft
When mine gets clogged, I use a similar process as Russ, I place a hose over the drain opening in the motor well and the blast of water acts like X-Lax.
- Jimmyt
A wet Vac also works to pull clogs out of that system. Place the Vac over one port and alternately plug the others so you pull through each leg.
DaveC426913
Once cleaned out, I have tried various methods for keeping it draining. (This is an X)
I tried a piece of canvas mesh rolled into a tube (to prevent debris from going down), but it wouldn't stay in place.
Now I just have one or two soft drink straws in the drain. Seems to be working.
Wayne nicol
mine bugged me so much, i cghanged it all, i put another thru hull- cant remember if it was an inch or 1.25 " on the transom, next to the existing one.
then i put a thru hull fitting in the motor well- cut out the other pathetic fitting, and just plumbed a straight line from the well top the outflow- and plumbed the sink to its own dedicated thru hull- and upgraded its size at the same time, and the hose from the sink to the thru hull.
so now if i blast the motor well fitting, it doesnt blow back up the sink, and the sink drains better too!
