I removed the aft berth cushions & now in storage & installed 3M plastic non-velcro two way to the panels to keep them in place I,ve also been thinkin of installing a rubber U shaped inverted block say 2" wide underneath & attached to the panels directly above the water ballast rib channels this would also help to keep them from moving around but most importantly keep them from collapsing when u either kneel or sit directly in the middle of the panels , I have 1/2"x 24"x24" approx foam cushions pads the all inter connect each one is a diff colour similar to below but bigger tiles
http://www.canadiantire.ca/en/pdp/safet ... p.html#srp
Just makes it much more comfortable when u have too go in there digging for something .
on each side I have two of those large plastic roller containers on wheels to store a lot of stuff in & they r clear so u can see whats in them & keep the stuff from rolling all around the place using masking tape or other & make a list of contents attached to each lid so as u know whats in each one
https://www.walmart.ca/en/ip/sterilite- ... 0194659475
this also allows u enough room to store ur cockpit & other seat cushions while not being used
in the center behind the step ladder I have my Blue lighted Subwoofer for my stereo & TV sound suround
& emg. safety gear & VHF hand held battery back-up , safety flares all contained in an emg. float able sealed container & large first aid kit bag
I always make sure nothing goes back in there loose that could poss. work it,s way back into the very rear & interfere with the auto pilot or steering gear mechanization
On the S/B side directly behind the aft dinette seat I keep my fridge/freezer
If I was ever going to use the aft berths for say extra crew on a cruise I,d buy either a double or two single bed air mattresses
Hope this gives u some Idea,s
