I also am aware that most of the water induction on these trailer boat thru hulls does not come into the cabin, most of it goes into the laminated layers of the fiberglass around bolts that have become loose from road vibration. That's why I do not like adding more places for glass to delaminate and I don't like covering up the fiberglass with backing so I can't SEE the de-lamination when it happens. I trailer my boat a lot and it has not got past me that every time I trailer down the road I am bouncing 250 pounds up and down on that thin piece of wood fiberglassed into the transom.
Thru Hulls are especially problematic on trailer boats because the hulls take so much punishment bouncing down the highway mile after mile.
It's bad enough all those bolts for the outboard - but I figured if there were a lot of de-lamination problems there we should have seen some failures by now. I need to think about this.
One thing I have learned over many years about thru hulls, if they ain't leaking, don't fix them so's they DO leak. I sort of hate to touch them.
I think the idea to move the thru hulls to as place above the waterline is one of the best ideas i have read so far.
