Hello , a new question ( may be already dealt with in previous posts) calling for help from the experienced sailors
In the directions for use of outboard it is indicated that if powering faster than 5mph both the FB and the rudders have to be up.
I tend to accept it FBwise but if I decide to put on engine for a fast return to harbour in case of that bad sea / wind conditions appear my experience is that using solely the outboard as rudder is not enough steering, specially to keep course in bad conditions. Also it is difficult to see what is 5mph SOW in these conditions. What is actually the reason for this?
Thks in advance
outboard operation in macX
Re: outboard operation in macX
The fins can't take the stress of high speed water against them. Also, the surfaces when turned sharply can creat "lift" and unexpected results.
I leave rudders down when I need extra steering, but rarely over 7MPH.
- Herschel
I really do not think you have to worry about the engine being able to steer the boat, especially if it is a 50 h.p going at a good speed. The only time you need the centerboard and rudders is going at a very slow speed with a lot of wind and even then mostly just when docking.
Wayne nicol
yup, when docking i put the rudders down and the dagger board about a foot.
really helps.
if its really windy, i will fill the ballast tank, another reason to have the rudders down, is so that they dont hook on anything at the dock- pilings etc, while in the up position.
really helps.
Wayne nicol
another thing,
the
has a dagger board, there really is no real reason to have flip up rudders,besides with them being cleated down, they wont flip up anyway.
i am going to look into a cassette type mod for the rudders- i really dont like those things sticking out the back when trailering or motoring.
the
- sunshinecoasting
Wayne's comment about hooking up rudders isn't really relevant in an
Our rudders stow vertical so no need to worry.
As for motoring with them down, yes you definitely get better control slow and at speed, I often motor full throttle with mine down and locked in position with the hold down rope, they don't cause any safety issues and they give incredible steering response, having said that I wouldn't want them to hit anything at 18 knots, I definitely don't motor at speed with the keel down.
