BOAT wrote:Hey Highlander,
Resurecting this thread on radars.
How is your radar working? Can you see the logs in the water?
I looked at the Garmin unit you suggested and I think your recommendation is the best one I have seen yet because the Garmin one you showed me has an auto bird gain function that can detect birds and stuff on the surface of the water:
But still is the question - is it worth the money? Are you getting usage out of radar? What do you use it for? Have you ever considered a camera on the mast to see better?
Mark
I just got my new units wired up & installed my GPS & temp. installed my Radar radome so as to make sure I did not damage the 30ft data cable I had pulled through the boat liner !
Had to remove 4 wiring harnesses for my old Lawrence unit then install 5 wiring harnesses for the new Raymarine system & I still have to install the 5th harness lol
Anyway GPS is working great , but the Radar would not connect " No connection " so after spending 3 days checking all my work to make sure I did not make a mistake or miss something & all my wiring connections & wiring harnesses were good I discovered I needed a software up-date 28 up-dates that took approx 40mins to download & only 20 mins to install , now the Radar is working good but I have designed an new radar arch to incorporate my Radar Radome & 3 solar panels & some other acc. but have been unable to get someone to make it for me this season
So at the moment can,t answer ur question , but a mast mounted camera is not gonna due u any good in a shipping lane with a ship coming at u at 20 knots plus in the rain or fog day or night !
As for affordability if u r up-grading like I was a MFD GPS unit only requires u to buy a radar radome to acquire full radar system
, if u already own a newer MFD GPS unit u may b able to just buy a radar radome to b able to acquire a radar system
so maybe some of the guy,s on here who already have the newer radar systems can cirp in , as for me it was a no brainier , but it is an individual call depending on ur needs & comfort level & what ur needs r gonna be !
PS I bought a whi/fi & data cable unit Radome
