2 pieces of 450mm x 180mm pine glued together, 25mm pipe from an old trampoline net holder,10mm bolt, flat steel, some cold galv spray paint and my dodgey welds
Soldering iron to etch image, 2 coats of varnish. next will be folding cockpit table and mount that will use the mast holder pipe thru the steering pedestal
