Rewiring lighting on 26D?
sebastien18
Sailboat: MacGregor 26D
Post by sebastien18 »
The wiring on my 26D needs to be replaced as the insulation has cracked and fallen off in sections. What's the best way to rewire the mast and other lighting?
Re: Rewiring lighting on 26D?
Post by K9Kampers »
Where possible, use the old wire to pull thru the new wire. Some routes may have multiple bends requiring pulling one straight at a time. If there are hole caps on the cabin ceiling, they can be removed to help with routing. An electricians fish tape is a worthwhile tool to have for this.
When I rewired my boat, one run along the side would not pull out. I ended up drilling a fist-size hole in the side liner and discovered that the factory ran the original wires to be sandwiched between the hull and the chainplate!
This job is not measured in time but rather # of cans consumed. It's helpful to know some of the magic words too!
Sumner
Post by Sumner »
sebastien18 wrote:The wiring on my 26D needs to be replaced as the insulation has cracked and fallen off in sections. What's the best way to rewire the mast and other lighting?
Here is a link where you can find info on how I wired the mast and it has eliminated all of the wire slapping inside the mast at anchor...
http://purplesagetradingpost.com/sumner ... de-42.html
...... and more on putting the foam on the wires here.....
http://purplesagetradingpost.com/sumner ... de-41.html
Here is a link to some of the rewire for the rest of the boat....
http://purplesagetradingpost.com/sumner ... de-30.html
Since then I found the fuses shown above they are easy to use at the battery and are not that expensive.
https://www.bluesea.com/products/5191/M ... 30_to_300A
They also have a two post/fuse one if that is needed. I used one on the Endeavour with two different size fuses for two different circuits.
One should have a fuse at the battery. Code now calls for it and it is just a very smart move to make. They go right on the battery so you can install one in minutes with your existing wiring,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
