I planned on running wires all over the new mast. I wanted an anchor, steaming, and spreader bar lights to name a few. Getting the caps off the sealed Hobie mast was quite a challenge, but when I finally was able to, I found that there was foam inside. I understand the practice of sawing PVC to create a drill bit but what's the practice for "dropping off wires" halfway up the mast?
I suppose I could lay the PVC pipe next to the mast and mark where I wanted the wires to be on the mast and then drill holes in the pvc, prewire the PVC with the wires sticking out of the holes I drilled in the PVC and then drill holes in the mast big enough to be able to get needle nose pliers in to pull the wires out? I'd have to get some grommets for the mast and then silicone around the wires to try to seal the holes.
Am I overthinking this or underthinking it?
