Tomfoolery wrote:Highlander wrote:Tom
Just cut the sucker off & then bolt a new one on like the Alum trl
& then its just a bolt off/on replacement !
is that poss. with ur trl ?
Can't do it, John - it's an all-steel trailer and the pole tongue is welded in several places. Mine's 18 years old and still in good shape, so it's still worth it to do some repair if needed.
As a side issue, I'm considering adding a load-equalizing hitch, but the tongue isn't strong enough on its own, without reinforcement. Or replacement. But it's far easier to stitch weld a second tube than to cut the original out and start again. I can also cut and fit and tack weld it into place and have a professional welder I know, who lives and works right down the street, do the finish welding.
If I ever get around to it.
Having towed a lot of things from a 1 ton utility trailer to a 7 ton, um, classified thingamajig in the USAF, I really don't think a load balancing hitch is needed for a 2.5 ton loaded trailer, as long as the tongue weight is 10-15% of the total weight, and as long as your tow vehicle weighs more than the trailer. I once was loaded up with 2 tons of topsoil in a dump trailer, with load balancing hitch, and because they loaded it too far aft, had nearly zero tongue weight. Once up to 45 MPH on a crowded highway, I was all over both lanes, cars in the ditch (didn't hit anyone, no injuries). Got it under control by bleeding off speed manually with trailer brakes, then limped off to a side road. The load distributing hitch did NOTHING. Spent the next 45 minutes shoveling topsoil forward, uneventful drive back after that. The tow vehicle is a 2006 F250 diesel, and I still tow the 26M at freeway speeds all the time, with just a regular ball hitch in the receiver. BTW, you can buy a hitch weight scale, or borrow mine if you pay round trip shipping and return it.
