It's true, even two strokes can be guilty of "makin oil" - I was running year old gasoline in my etec60 at idle for a long time since my wife hates the motor I don't run it much so after several trips like that when I got home with the boat in the driveway sitting for several hot days there was "oil" dripping out of the prop where the exhaust port is. It was a black sticky goo kind of 'oil'. The old gasoline was turned into bunker C as it was slowly cooked in the exhaust manifolds. I put in fresh gas and went for a real nice wide open throttle trip with a buddy out in the ocean for about 30 minutes - the next thing we knew we were out in the middle of nowhere so we had a nice sail. The motor did not leak a drop after that.Highlander wrote:Hate to inform U that u are wrong "the term" Making Oil is used in the trade as describing a fluid leaking into the crankcase & therefore raising the oil level ! 'Thus using the term "Making Oil"grady wrote:There is no such thing as making oil. Your oil system is getting contaminated with somthing. Most likely fuel. 2003 model carbureted? A float needle leaking?
Also excess idling is well known in the trade to cause "makin oil" as unburned gas or deisel leaks down into the crankcase , same as excess idling a diesel eng in certain weather condintions can fill the crankcase with water "due to excess "moisture in the air created in the crankcase " forms into water as it cools down
I will make sure I always use fresh gas and to make sure I do not ONLY IDLE the motor all the time (I will try to use the motor more often).
