MacGregor 26m Stay lengths
Hi Folks,
I'm having dyneema stays made so I figured I'd document my 3 year old stock stay construction and lengths.
Upper Stays:
:: Length, from eyelet inner top to eyelet inner top (i.e., the point at which the tangs touch the eyelet:
24'11"
:: Distance to spreader connector from upper inner top eyelet to top of spreader connector:
11'10"
Macgregor 26m spreader Connector by matthew_strebe, on Flickr
top tang length: 3"
Macgregor 26m upper stay top tang by matthew_strebe, on Flickr
bottom tang length: 6"
Lower Stays:
13' 0.5"
Re: MacGregor 26m Stay lengths
No top tang:
MacGregor 26m Lower stay top by matthew_strebe, on Flickr
Macgregor 26m lower shroud bottom by matthew_strebe, on Flickr
Globalhobo
Post by Globalhobo »
This helped us a bunch - we're making our own because the PO cut the old shrouds off!!! :?
Neo
Post by Neo »
Globalhobo wrote:....the PO cut the old shrouds off!!! :?
Any idea why he did that? :o
All the best.
Neo
Globalhobo
No idea. Unfortunately, he trashed the boat in a ton of inexplicable ways. It's the reason we got it so cheap but also why it's still not in the water. :( I did find the original packing list that had the stay lengths on it. It was slightly different to your measurements. Did yours have the small tang at t the top?
Thanks!
In the world of Macgregor QC I would not expect measurements of shroud length to transfer from boat to boat
Neo
Post by Neo »
There are two different lengths for the "M" ... with or without the Tangs .... Best to have Tangs if you can.... keeps the eyelets from scratching the Mast and less stay tangles too :)
Globalhobo
Neo wrote:There are two different lengths for the "M" ... with or without the Tangs .... Best to have Tangs if you can.... keeps the eyelets from scratching the Mast and less stay tangles too :)
Thanks, Neo. I found the original packing list that has the rigging lengths on them! Only problem is that it doesn't say whether those lengths are with or without tangs. I'm going to assume that since you said your measurements were eyelet to eyelet, that they are without tangs. We have lengths of cable to make them and I ordered the stay adjusters from BWY, so we'll just go with that, I suppose. :)
Neo
Post by Neo »
There's plenty of adjustment on the stay adjusters. But make sure you have the baby stays with only a small amount of slack when the mast is down but locked into the base. With no wind around the baby stays and the Mask Raising System (MRS) can hold the mast up while you check/adjust the stay lengths. ... Make sure the boat id level before you start.
I swear by using this method when raising/lowering the Mast http://www.macgregorsailors.com/forum/v ... ilit=+baby ..... I lowered the mast in a 17 Knot wind today with hardly any mast sway.... Straight into the mast holder :)
Also when it comes to the final tensioning adjustments on the stays. With the baby stays attached you can slacken the MRS so the stay go slack and it's dead easy to take the stay adjusters up a notch. :)
Best of luck.
Neo
Globalhobo
Thanks, Neo!
We don't actually have a MRS. The PO broke the winch and who knows what he did with the pole, etc. We found some crinkled up old wire that used to be the baby stays...we think. :?
Anyway, we will try the ole 2 man tilt up when we finally get her ready to try to rig.
I'll let you know how it goes. We are currently re-building a crashed up daggerboard, hopefully before the bottom paint goes on day after tomorrow.
aloha!
Neo
Post by Neo »
Sounds like you have a lot of work to do :?
Please build yourself an MRS and baby stays they are so important for raising and lowering that 30ft mast. Especially the 1st time :| ... I can give you all the dimensions if you need them? ... Also see BWY http://shop.bwyachts.com/category-s/404.htm
Best of luck
Neo
