http://s1121.photobucket.com/user/rottn ... 1.jpg.html
The following began with cutting and welding three mast sections along with the incorporation of 30 bolt-rope sliders for the tarp last fall. It wasn't until this spring that I began to buy the hinge and other necessary hardware as well as ,yet, drilling more holes through my transom.
http://i1121.photobucket.com/albums/l52 ... wsxelf.jpg
I made a cut-out template for the tarpaulin I wanted made and let the outfitter decide the stitching and reinforcing regimen. The material is high tech truck tarpaulin (cheaper than my first choice - sunbrella) which won't stretch and will take a large load. This was secured with 120lb uv proof ties (X30).
http://i1121.photobucket.com/albums/l52 ... mup6pn.jpg
http://i1121.photobucket.com/albums/l52 ... 7uass9.jpg
The act of finally lowering the frame adds the right amount of tension to the material though the photo doesn't have the inner clamps attached for holding the working shape. I'd designed the outboard cutout to allow stowing clearance for trailering or lowering with the engine already down.
http://i1121.photobucket.com/albums/l52 ... 6uoojq.jpg
http://i1121.photobucket.com/albums/l52 ... ptjtkd.jpg
http://i1121.photobucket.com/albums/l52 ... jedoyn.jpg
The one finalization I haven't arrived at yet concerns the simple pully and rope I added for the interim. I need either to get it swapped with good non-stretch (bouncy) synthetic material or go to a telescopic pole of some kind. I'm leaning towards the latter as long as I can lower the outboard end directly into the water for my Admiral to easily climb into the boat. She's a stroke survivor and the stock ladder is very difficult for her.
I hope some of you find this solution interesting, and yes I have quite a bit of mast left over for the asking.
Ross
