If you're talking to a mast supplier, then I'm sure he/she has looked at the properties of the original, or at least the latest version, of the custom extrusion MacGregor used. http://www.macgregor26.com/suppliers_co ... ty_rr.html
Do be careful about the strength of the new extrusion, which is easy enough to determine from the specs in the drawing. Make sure the Ix and Iy values (those are 'eyes', not 'ells') are met or exceeded. They're a measure of the distribution of the metal in the two primary directions of bending (fore/aft, and side-to-side), and relate in conjunction with the material strength, to the bending stiffness and strength of the mast. Outside dimensions alone aren't enough, though you can probably get close(ish) with outside dims and wall thickness. That's why all mast manufacturers give those specs. Same with booms and spreaders.
But I also agree that you should call or email BWY - they're great folks, and they may know of either a mast in your area, or how to get one to you for cheap(ish), or perhaps a reasonable replacement from a catalog that you can source locally. Worth an email at least.
Oh, and if it were me, I'd look into splicing the broken mast. Maybe it's the junkyard mentality in me, or the New England attitude (where I grew up), but an otherwise perfectly good mast that's very expensive to replace would warrant serious consideration for splicing. At least to me.
