I have a red/green on the fwd part of the mast 3/4 of the way above the headstay. The anchor light has been modified to only shine aft when the mast red/green is on. I put the mast running light on because with my bowsprit and asym spin will cover up the lower runnning lights.Tomfoolery wrote:What are the 'mast running lights'? The masthead is the 'steaming' light, and the anchor light is self-explanatory. Are you using a tri-color at the top when sailing after sundown?grady wrote:Mast running lightsRussMT wrote:What did you use 9 connectors for? Whatcha got up there?
Anchor light
Mast head light
Spreader lights
Ground
Wind indicator takes up the last 4 pins.
Wiring Mast Lights
Re: Wiring Mast Lights
Just wanted to make a note. My masthead wires make an stupid slapping noise inside my mast. I only just figured this out as i thought it was mainsheet and jib lines flapping along exterior but nope, inside mast. I had thought of ramming a few of those kids pool noodles in there or something. maybe someone has a better idea. just a thought
Braxon
Braxon
- Spector
- Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
When I re-did my mast wires I put a zip tie on the wires every few feet and left the tail on them. it has worked well to stop the slapJonair222 wrote:Just wanted to make a note. My masthead wires make an stupid slapping noise inside my mast. I only just figured this out as i thought it was mainsheet and jib lines flapping along exterior but nope, inside mast. I had thought of ramming a few of those kids pool noodles in there or something. maybe someone has a better idea. just a thought
Braxon
This is a good way to keep the wires "suspended" so they don't bounce around. The pool noodle will work if you can slide it down the offending wires.Spector wrote:When I re-did my mast wires I put a zip tie on the wires every few feet and left the tail on them. it has worked well to stop the slap
You could also fill the mast with Styrofoam packing peanuts. Just be sure to use real Styrofoam peanuts and not those corn starch peanuts that melt when wet.
- Sumner
I had...Jonair222 wrote:Just wanted to make a note. My masthead wires make an stupid slapping noise inside my mast. I only just figured this out as i thought it was mainsheet and jib lines flapping along exterior but nope, inside mast. I had thought of ramming a few of those kids pool noodles in there or something. maybe someone has a better idea. just a thought
Braxon
...some dry-fast foam left over from the cockpit cushions....
...so used it...
... and it has worked great...
http://purplesagetradingpost.com/sumner ... de-41.html
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
That is similar to what we did years ago with a boat. It does work well. Good use of scrap foam.Sumner wrote: I had...
We pulled blocks of V shaped blocks of foam up the mast that pinched the wires against the inside.
- ULLR
I have had the same problem with mast wiring making a tinging noise when docked in rough weather. No matter how well I tied up the halyards it went on through the night...finally realized it was inside the mast, pulled the wire tight and it almost went away. Didn't sleep more than 15 mins straight that night so needless to say it is on my winter repair list. I had kind of envisioned adding some sort of foam disks around the wire so good to see the pics.
U know all those little sponges r gonna suck-up all ur electrical power off these wires right !!
- Sumner
I guess that explains why my anchor light was dimmer after installing the foamHighlander wrote:U know all those little sponges r gonna suck-up all ur electrical power off these wires right !!![]()
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
- ULLR
I finally fixed the ringing noise in the mast. Tied a rope to one end of the wiring and then pulled the wire out of the mast from the other end. I then attached tie straps every foot leaving the tails on....once complete pulled wire back through using rope. Just like magic....tinging noise gone and can sleep soundly! Thanks for the tips.
- sailboatmike
Ahhh Halyard clanking the bane of my life, not only on my boat but on those around me.
My partner finds it soothing, on the other hand I find it like nails on a blackboard.
BUT here is the rub, she cant sleep with any noise in the house, but halyard clanking soothes her to sleep, me on the other hand cant sleep without the TV on, but one clank from a Halyard and Im wide awake, go figure that
Leaving the ends of the zip ties on is important for this trick.ULLR wrote:I finally fixed the ringing noise in the mast. Tied a rope to one end of the wiring and then pulled the wire out of the mast from the other end. I then attached tie straps every foot leaving the tails on....once complete pulled wire back through using rope. Just like magic....tinging noise gone and can sleep soundly! Thanks for the tips.
