speed over water vs speed over land
bobbob
Re: speed over water vs speed over land
Thanks. I am reasonably certain its a 20" shaft. I think I read somewhere that the plate above the prop should be right around the water line?
- beene
That plate needs to be even with the bottom of you boat, not waterlinebobbob wrote:Thanks. I am reasonably certain its a 20" shaft. I think I read somewhere that the plate above the prop should be right around the water line?
With an M, thats at the keel area, about an inch below the transom bottom.
- sailboatmike
We had a perfect SOG Vs SOW yesterday. light wind sailing into the incoming tide of around 3Knts, we sailed just about in place for around 45 minutes, I recon we made no more than 150 meters actual headway in that time which was perfect because we got to play with sail settings and adjustment and have a cup of coffee without having to worry about running into anyone or out of room.
Speed Over Ground = Best part of zero
Speed over water = About 3Knts
Then we turned 90 degrees onto a broad reach across the tide and she kicked up her heels like a philly let lose in a field and came alive
Brilliant sail and very relaxing
