What sealant is used on thru-hull deck bolts?
mitchmiller
Post by mitchmiller »
There is water leaking around the bolts which attach the genoa jam cleats on my 2006 26M. I took off the mirror cover and can see the drips. There is a soft white sealant on the nuts and bolts that is still soft and tacky. First I want to put more of this sealant to try to fix the leak.
If that doesn't work, I will take off and re-set the cleats - but they nut and bolt will still need to be sealed anyway.
Does anyone know what type of sealant was used?
kadet
Re: What sealant is used on thru-hull deck bolts?
Post by kadet »
You can use a marine polyurethane sealant like Sikaflex - 291 or 3M 5200, note these also double as adhesives as well.
seahouse
Post by seahouse »
http://www.westmarine.com/buy/captain-t ... oz--243990
This will fill small cracks and voids of the type you mention by capillary action, but is not the factory sealant.
Seapup
Post by Seapup »
Good how to on rebedding hardware so it will last:
http://www.pbase.com/mainecruising/rebe ... are&page=2
I have about 300 of my 400 leaks stopped on the other boat using it and wished I had tried it sooner.
Paul S
Post by Paul S »
Seapup wrote:Good how to on rebedding hardware so it will last:
Yes their butyl tape is the best and only choice.
