Mast light Bulb
- 1-Tntimbo
Mast light Bulb
My mast light quit working, I removed the bulb with intentions of replacing it, but have lost the bulb.
Does anyone have the correct bulb number for replacement. (2000 26X)
Tim
Tim
Re: Mast light Bulb
Are you talking about the steaming light..forward facing fixture?
Don't know about the X, but the M uses a 42mm festoon bulb.
Re: Mast light Bulb
Here's a recent thread on that, including LED replacements. I have pics of mine on the second page, for reference. http://www.macgregorsailors.com/forum/v ... ad#p300252
Re: Mast light Bulb
RussMT wrote:Are you talking about the steaming light..forward facing fixture?
I recently replaced my1-Tntimbo wrote:26X bulb did not look like that, has flat drum type ends.
T
- Cougar
Re: Mast light Bulb
The mast light in an
needs a barrel end festoon bulb, such as this one: http://marineledshop.com/navigation-bul ... el-festoon
I put one in last winter and it's exceptionally bright.
Re: Mast light Bulb
My guess is the cone shaped ends would work, however if it must be barrel ends, how about this one.
http://www.amazon.com/LEDwholesalers-Aq ... ulb+barrel
Re: Mast light Bulb
AFAIK, this is the original masthead (steaming) light, as found on my
Looks like the bulbs ends are flat, with a small dimple in the ends.
- Chinook
Re: Mast light Bulb
If you want to replace with LED, replacement bulbs are available which come with multiple terminal caps, including pointed and flat caps.
Re: Mast light Bulb
Tom, that looks like an old style festoon bulb. It pinches in from the ends, so I do believe the cone end style would still work. I manually bent the ends of my connectors to add more spring tension to hold it in tighter. Looks much like the M steaming light if you ask me.Tomfoolery wrote:AFAIK, this is the original masthead (steaming) light, as found on my.
Also should be noted that LEDs are polarity sensitive. Festoons are easy to reverse polarity by inverting it if not lighting up.
- Phil M
Re: Mast light Bulb
RussMT wrote:My guess is the cone shaped ends would work, however if it must be barrel ends, how about this one.
I finally got around to ordering an LED from this company. I installed it and it is quite bright too. Maybe now I will actually use this light once in awhile.
