This is the first boat we've owned with a water system.
It seems simple enough. More simple that the electrical...that's another post. Yikes.
But I have two questions.
There are three hoses coming off the holding tank.
1. The larger of the three leads to an interior "fill cap?" in the v-berth labeled water. I'm assuming this is where we add water to the tank. The hose dips from the 'fill cap' to the floor of the v-berth and rises again to the top of the tank, on level with the 'cap' (as far as elevation is concerned.) How does the water actually fill the tank instead of just filling the hose and backing up out of the 'fill cap'? Are we suppose to run the water pump to create a vacuum? Will the pump run and do that by just snapping it on at the breaker panel without running the faucet?
2. The second hose runs from the tank to the water pump. Got that. But the third runs straight up the head wall into the bulk head...but to where??? Is it just a vent to burb the system? We can't pull the bulk head away and peek. (the bulk heads in the main salon have enough give to do that.)
Thanks!!!
Barb aboard Do We: 979.124
