But the question of what weight should we prop for is legit. Thoughts?
" I'll be using a Pontoon 115HP on a waterballasted motor sailor [ A what?]
A MacGregor 26X Powersailor - bear with me a moment. My boat dry, unballasted weighs about 3500lbs. This would be it's weight for motoring & normally what I'd use to prop boat for WOT.
When sailing you open a valve at the transom & in comes 1400lbs of water for ballast. Making boat weigh ~ 5000lbs. You close valve once full. While a bit tippier than a reg lead Keel boat this feature, along with a semi displacement flat bottomed hull, allows for motoring speeds up to 24mph, while unballasted.
When it's choppy or snotty I'll motor with the ballast in because it helps to center the boat & give a calmer ride. To de-ballast you open the valve and motor off over 8mph and the ballast will dump in 5 mins depending on speed.
Here's my question: Should I prop for WOT with the ballast in? To not lug the motor for slower speeds in chop while ballasted
Should that 1400lb weight difference concern propping? How?
I probably motored with ballast in ~15 - 20hrs last season due to conditions.
This is part of the reason why I went with the pontoon line. As sometimes you'll run with 1 or 2 people & sometimes with 10, on a pontoon. How should this affect prop choice?"
